Dato og tid er 20 okt 2025, 14:55
Indlæg: 15 okt 2009, 10:09
Tilmeldt: 10 mar 2006, 10:26
Geografisk sted: Brædstrup
Jeg har en lille motor ombygning i tankerne men det volder mig lidt problemer at regne ud hvad det nye kompressions forhold vil blive. :reading:
Motoren som den er nu:
Antal cyl: 6
Boring: 84 mm
Slag: 75 mm
Pejlstang: 135 mm
Slagvol: 2493 ccm
Komp. nu 8,8:1 (aflæst fra data blad)
Motoren som den var tænkt i fremtid
Antal cyl: 6
Boring: 84 mm
Slag: 81 mm
Pejlstang: 130 mm
Slagvol: 2693 ccm
Komp. ??
Er lidt i tvivl om jeg skal bruge mere motor data for at regne det ud. Kan jeg godt regne ud at stemplet kommer til at toppe 2mm før top end før. Men det kan vel ikke sammenlignes med at blot knalde en tykkere toppakning i når man også øger slaglængden. Kan ikke helt lure hvordan det skal regnes ud.
Nogen der har noget indput?
:coffee:
Indlæg: 15 okt 2009, 11:38
Tilmeldt: 27 okt 2005, 16:40
Compression Ratio
Information required:
1) Capacity of ONE cylinder
2) Compressed volume
Cylinder capacity is the total engine displacement divided by the number of cylinders.
E.g. 4 cylinder 1600cc engine = 400cc per cylinder.
Compressed volume is the area above the piston crown when the piston is at its highest point or top dead centre (TDC).
This area comprises:
1) The combustion chamber (usually in the cylinder head as shown, but can also be in the piston crown),
2) The head gasket thickness,
3) The area between the cylinder block face and the piston crown, commonly referred to as the 'deck height'.
Procedure:
Measure the volume of the cylinder and/or piston chambers using a suitable burette filled with paraffin. Calculate the volume of the gasket and deck height areas and add these to the chamber volume to arrive at the total compressed volume. Some engines with irregular piston crown shapes, especially raised areas, may be difficult to quantify with any degree of accuracy. In such cases it is best to measure the compressed area with the cylinder head fitted. Make sure the piston is at TDC and seal the gap between the cylinder wall and the piston with grease (this will prevent seepage past the rings giving a false reading).
Refit gasket and cylinder head and measure the volume through the spark plug hole.
NOTE: The spark plug hole must be at the highest point when carrying out this procedure.
Calculation: (Cylinder volume + compressed volume) ÷ compressed volume.
Example: 2000cc 4 cylinder engine with a compressed volume of 54cc's
Solution: One cylinder = 2000cc ÷ 4 = 500cc
(500cc + 54cc) ÷ 54cc = 554cc ÷ 54 = 10.26 or 10.26:1 compression ratio
håber at du kan bruge det her
Indlæg: 15 okt 2009, 16:16
Tilmeldt: 08 jul 2003, 13:19
Måske det kan hjælpe lidt.
http://www.turbomotor.dk/formel_kompretion.xls
Indlæg: 15 okt 2009, 16:26
Tilmeldt: 22 mar 2009, 12:49
du er jo nød til at vide hvor stort volumen du har over stemplet når stempel er i top.
så enten skal du udmåle forbrændingskammer i topstykke/stempel,toppakning, eller samle motor med en gammel toppakning og så køre et stempel i top.
derefter måler du hvor meget væske der kan være over stemplet, ved at bruge en stor kanyle fyldt med eks 100ml kølervæske , fyld så væsken ned i cyl gemmen hullet til tændrøret , men kun op til gevindet.
ps: husk at motor skal stå så tændrøret står lodret
nu kan du så afmåle på kanylen hvor meget væske der er i motoren.
nu kan du så lave det regnestykke der er i indlæget højere oppe :-)
Indlæg: 15 okt 2009, 17:20
Tilmeldt: 02 okt 2003, 09:19
Geografisk sted: Fredericia
mon ikke det kan klares lidt lettere..... eks 10%mere volume = 10% mere komp ? (det kan det inde i mit hoved ;-))
Indlæg: 15 okt 2009, 18:43
jo , men det er jo lidt som at arbejde i blinde, for man kender jo ikke kompresionen på den gamle motor.
de tal der opgives er jo fabriksdata, og de holder jo ikke når blok og top er planet :wink:
så jeg ville nu få det hele udmålt så man kender det 100%, jeg lavede selv den udregning på min tidligere e30 turbo
Indlæg: 16 okt 2009, 07:09
Har faktisk selv lavet et regne ark i går som kan regne det samme ud som det Finn linker til fra turbo motor af.
Kan ikke se hvorfor volumen over stempelet skal blandes ind i det, når man kender det gamle komp. forhold. Du har selvfølgeligt ret i at det kan være ændret en smule fordi det er blevet planet noget af. Men nu ved jeg hvor meget der er taget af blok og top, og det er altså så lidt at det ikke ændre mere end ca. 0,15 på komp. forholdet. Men du har selvfølgeligt ret i at man så bør regne ud fra 8,95:1 i stedet for 8,8:1
Skal ikke have noget vildt spændende i skolen idag så må prøve at regne lidt videre på. :reading:
Men indtil videre foreløbigt tak for hjælpen :)
Indlæg: 16 okt 2009, 08:52
hvilke stempler har du tænkt dig at bruge ?
for som jeg husker det så kan du ikke bruge m20b25 stempler sammen med en eta/diesel krumtap og 130mm stænger.
krydspinden sidder ikke samme sted i et eta stempel vs 25i stempel
Indlæg: 16 okt 2009, 09:37
Der skal bruges 25i kat stempler, de skal en tur i en fræser og have taget lidt af skørterne for at de kan vende for krumtappen.
Har regnet ud at den ender på omkring 8:1 i komp. Hvilket også svare til det jeg har kunnet læse mig til på div bmw sider.
Har dog også fået en krumtap med 84mm slag på hånden. Men den kræver nye stempler for at kommer til at virke.
Indlæg: 16 okt 2009, 20:48
Har lavet et lille regne ark. Dem der har lyst kan jo tage et kig på det og komme med en kommentar til om i mener at det er rigtigt eller forkert det jeg kommer frem til. :ha:
Senest rettet af JDJ 26 okt 2009, 20:47, rettet i alt 1 gang.
