knast
Ford'en
Tilmeldt: 20 mar 2005, 18:44
knast
#1 Indlæg af Ford'en »
kan jeg bruge den her knast i min bil
bilen er en ford escort xr3i fra 86 mk4
Manufacturer : Kent Cams
Category : Kent Cams - Ford
Sub-category : 1.3/1.4/1.6 CVH Hydraulic
Application : Cam - Super Sports - BL
Product Code: KC-CVH33-BL
Details : Estimated Power Gain = 20 Bhp
Powerband = 2500 - 7000rpm.
Valve Lift (Inlet/Exhaust) = 12.14mm Inlet 11.63mm exhaust
Duration (Inlet/Exhaust) = 290 285 Degrees
Timing (Inlet Open/Close)/(Exhaust Open/Close) = 36/74 72/33
Full Lift (Inlet/Exhaust) = 109 Degrees
Valve Clearance = 0.00mm
Dagooz
Tilmeldt: 03 maj 2004, 00:37
Geografisk sted: Vejle
#2 Indlæg af Dagooz »
Offtopic: Det er en MEGET optimistisk effektforøgelse de opgiver der...
Kære brevkasse,
Ford'en
#3 Indlæg af Ford'en »
Dagooz skrev:Offtopic: Det er en MEGET optimistisk effektforøgelse de opgiver der...
ja der var os nogen mindre nogen
Application : Cam - Sports Injection - BL
Product Code: KC-CVH32-BL
Details : Estimated Power Gain = 14 Bhp
Powerband = 1000 - 6500rpm.
Valve Lift (Inlet/Exhaust) = 11.37mm Inlet 11.04mm exhaust
Duration (Inlet/Exhaust) = 280 273 degrees
Timing (Inlet Open/Close)/(Exhaust Open/Close) = 25/75 63/30
Full Lift (Inlet/Exhaust) = 115 Degrees
s@g
Tilmeldt: 21 nov 2003, 23:30
#4 Indlæg af s@g »
Fra : http://www.pumaracing.co.uk/cvh.htm
The CVH22 will run with the standard valve springs and is worth about 6 or 7 bhp with decent low rpm tractability. The CVH33 is about as far as you can go with a road cam and still retain any sort of driveability. It loses out under 2,000 rpm but gives about 10 to 12 bhp at the top end. Lift is too high for the standard springs. Copyright David Baker and Puma Race Engines
Fra : http://www.kentcams.com/index.htm
Ford CVH 1.3, 1.4, 1.6 CVH22K Sports 'R' Camshaft 15 Bhp
Ford CVH 1.3, 1.4, 1.6 CVH33K Competition Camshaft 20 Bhp
Fri bane, fuld hane!!!
