Dato og tid er 06 sep 2025, 07:04
Indlæg: 14 sep 2006, 22:29
Tilmeldt: 17 sep 2003, 18:05
Geografisk sted: Danmark
Hvad skal man tjekke i Megatune ved sådan et dyse skift ?
software version 24s13c
Senest rettet af Mark 19 sep 2006, 09:50, rettet i alt 1 gang.
Indlæg: 19 sep 2006, 09:49
upp..... hvordan skal de PWM settings stå ? ved højohms dyser
Indlæg: 19 sep 2006, 10:26
Tilmeldt: 06 jul 2003, 19:07
Her er snippet lidt fra vejledningen på www.megasquirt.info
On the Settings/Constants page:
If you are running high-impedance injectors (greater than 10 Ohms), then set the:
PWM Time Threshold to 25.4 msec, and the
PWM Current Limit (%) to 100%.
If you have low impedance injectors (less than 4 Ohms), set the:
PWM Time Threshold to 1.0 msec, and
PWM Current Limit to 75%(30% if you have installed the 'Flyback Board' daughter card).
You will tune these after getting the engine running. See “Setting the PWM Criteria” in this section. Failure to perform these steps can result in damage to your injectors. If you have high-impedance injectors, set these values to 25.4 ms and 100%, and you do not need to tune them further.
Søg mere info her:
http://www.megamanual.com/v22manual/mtune.htm
Daniel.
www.fischer-saab.com
