Dato og tid er 05 nov 2025, 06:30
Indlæg: 07 dec 2009, 21:24
Tilmeldt: 30 jan 2005, 08:54
Spritny
Super T70 kinalader
2500,-
Rajay turbo
Spritny
Den har det patenterede kuglesystem fra Rajay (nu opkøbt af turbonetics)
Den er bygget som en tank!
Mål: (cirka mål)
Kompressor: ca. inducer58mm exducer82-84mm A/R ca. .50/.60, Indgang 3', udgang 60mm
Turbine: ca exducer58mm inducer74-78mm A/R 1.0. BEMÆRK indgang turbine 3' v-clamp single. Afgang 3' v-clamp. Altså indgang + udgang med v-clamp 3' (som tial)
Vand og oliekølet
Meget kompakt lille og let turbo
250 - 550hk burde ikke være umulig
Nypris (dengang) 14kg
Sælges som spritny for hbo 3500,-
Senest rettet af JPP 21 dec 2009, 18:42, rettet i alt 2 gange.
Indlæg: 15 dec 2009, 01:18
Rajay turbo: Vil tro den ligger meget tæt op af GT3076R / GT3082R
Som sagt også med kugleleje...
Passer også fint til de mindre motorer der skal yde højt under lavt modtryk
Indlæg: 15 dec 2009, 06:40
meget speciel! har den været beregnet til en flyver? eller?
hvor gammel tror du den er?
MVH søren
Indlæg: 15 dec 2009, 11:48
MVH søren
Kunne MEGET vel tænkes -
A brief history of the five manufacturers
who have owned the
RAJAY turbocharger line:
- 1958 — TRW (Thompson-Ramo-
Wooldrige of Cleveland, OH) develops
the 300 Series Turbocharger.
- 1969 —RAJAY Industries (Long
Beach, CA.), a unit of the Texstar Corp.
in Grand Prairie, TX, acquires the
entire TRW Turbocharger line. Texstar
later became a unit of the Hillman Co.
of Pittsburgh, PA.
- 1982 — Roto-Master Inc. (North
Hollywood, CA), later a unit of Echlin
Corp. (Branford, CT) acquires the
entire RAJAY Industries operation from
Hillman Co., including the RAJAY
STC’s for aircraft kits.
- 1986 — AiResearch Industrial
Division of the Garrett Corporation,
now AlliedSignal Automotive, acquires
the entire operation of Roto-Master
from Echlin Corporation and relocates
it to the Garrett turbocharger facilities
in Torrance, CA.
- 1995 — RAJAY turbocharger STCs
were divested of to Consolidated Fuel
Systems in Montgomery, AL.
- 1997 — Consolidated Fuel Systems
(Montgomery, AL.), a division of Kelly
Aerospace, announces in August its
purchase of the RAJAY turbocharger
line from AlliedSignal. This purchase
includes manufacturing, engineering,
and design rights to both aircraft and
automotive turbochargers.
:coffee:
Indlæg: 15 dec 2009, 20:40
Det er flyturbo !!
Også derfor der er mulighed for flere olie og vandudtag.
Havde tvillingebror som blev bortarborteret
Indkøbt fra usa omkring 2000/2001
Rajay leverede primært flyturboer, men også til motorcykler biler mv.
Mange af disse sidder på biler. Det bliver de bestemt ikke dårligere af :wink:
Turbonetics solgte dem frem til 2004 svjh.
Indlæg: 16 dec 2009, 04:52
ærgerligt der ikke er to mere.... spændende er de. dvs nu kun den!
Indlæg: 20 dec 2009, 14:21
Tilmeldt: 11 maj 2004, 17:06
Geografisk sted: østfyn
hvor gammel er den t70 turbo og hvad gevin er den på kompresser siden alså det der holder kompresser hjulet
Indlæg: 20 dec 2009, 17:08
Begge turboer (inkl. T70) spritnye!
Jeg ved ikke hvad du mener med gevind på kompressorsiden - tænker du på den anden Rajay turbo? Det er to forskellige turboer jeg har til salg :wink:
Indlæg: 20 dec 2009, 20:20
er der højre eller venstre gevin på kompresser siden det er fordi at de første t70 turboer der kom var med højre gevin og så smid de møtrikken til og holde kompresser hjulet og det har jeg lige gjort :(
Indlæg: 21 dec 2009, 10:04
Tilmeldt: 21 jun 2007, 13:17
Som Søren siger, ærgeligt der ikke er to af de turboer, jeg skulle gerne ha været røget på...
corvus terrae terror...
