Hej.Mangler en fitting.har ledt alle steder på nettet syndtes jeg.men kan ikke finde lige denne type.er der en klog en der kan hjælpe med det.
Den skal hedde 5/8-18 unf til jic 10
pakker med en o-ring ved 5/8-18 siden
Passer 5/8-18 unf overens med andet??måske??
Den er forøvrigt til en oliefilter relocator adapter.
vedlægger et foto af sådan en.
Hilsen Martin
jic fitting
- martin høj
- Mester Medlem
- Tilmeldt: 05 aug 2008, 20:43
- Geografisk sted: KBH
jic fitting
- Vedhæftede filer
- 5.jpg (123.41 KiB) Vist 5265 gange
- martin høj
- Mester Medlem
- martin høj
- Mester Medlem
- klyfax
- Mester Medlem
- Tilmeldt: 25 maj 2005, 10:08
- Geografisk sted: Sweden
Hvad med den lokale traktor pusher? Eller evt. Hydra-Grene...
http://hydra.greneonline.com/webapp/wcs ... reId=11000
- ae86
- Mester Medlem
- Tilmeldt: 12 jan 2007, 00:08
JIC fittings are similar in size, threading and flare seating to AN fittings ..
JIC fittings, or SAE J514, or MIL-F-18866, are a type of flare fitting having 37-degree flare seating surfaces and are widely used in hydraulic applications. ...
Common meterials of construction include stainless steel, forging brass, machining brass, Monel, and nickel-copper alloys....
(Dit billedet er umildbart en blå eluxeret aluminiums samling ... hvilket får mig til at tro det er en AN)
... I just spoke to a rep. from the Parker Haniffin Corp. I asked him whether or not the JIC 37* fitting was interchangeable with the -8 AN fitting. He said that "it's not recommended for aircraft use...". The only difference between the two are the threads. The AN fitting has 3A/3B threads and the JIC fitting has 2A/2B threads. The guy said it would be fine for pressures < 150 psi....
... yes they are interchangeable the only diffrence it the threads on an jic are more pointed and the AN have more of a radiud on them so that they are harder to crossthread i work with fluid power stuff every dan and they are completly interchangeable to at least 3000 psi is the most i have ran in the two but i hope you never see fuelpressure that high any way....
- martin høj
- Mester Medlem
Tak for info.Havde læst det samme et sted.Og har selvfølgelig undersøgt i an standarden også.Men heller ikke held der.
Nå men skal jo videre med det hele.Så har lavet noget nyt gevind i oliebøffen. 5/8-18 er næsten det samme som mm gevind.Så det skulle kun lige rives en anelse.Og fik så sammensat lidt,som er blevet sølvloddet.Og bruger så banjobolte istedet. Smider et billede med så i kan se hvad jeg har gjort.Kunne jo være en anden har samme problem et sted i lille danmark.
Men vil da gerne stadig have lidt info om 5/8 fitting.
MVH:Martin
MVH:Martin
- Vedhæftede filer
- 22092008147.jpg (61.46 KiB) Vist 5233 gange
