Controlled auto ignition
Generel teknik
JPP
Tilmeldt: 30 jan 2005, 08:54
#1 Indlæg af JPP »
"Controlled auto ignition" sætter ligesom pre-ignition i et nyt perspektiv. Vel også en lille add-on-udfordring for fremtidens after market engine management systems at styre nedenstående opsætning.
I mine øre voldsomt interessant emne... ligesom "variable compression ratio", mener Saab var tidligt på banen her.... :reading:
http://fpn.dk/motor/article1022016.ece
Mercedes-Benz DiesOtto – a further development of the spark-ignition engine
" In line with the worldwide success of today's diesel engine, vehicles equipped with gasoline engines will continue to have a long-term attraction for many customers and in many markets. Accordingly we are giving our attention to both engine types – including a full hybrid option for diesel and gasoline vehicles, " says Prof. Kohler. Mercedes-Benz is working on its DiesOtto concept with corresponding emphasis. Its key technological features are as follows:
- Downsizing with fewer cylinders and a smaller displacement
- Turbocharging for superior performance
- Direct gasoline injection as a further fuel economy measure
- Controlled auto ignition, a combustion process similar to that of a diesel
- Variable valve control
- A variable compression ratio leading to even better fuel economy and, depending on customer needs and the type of operation,
- A hybrid module with an integrated starter/generator, which makes the drive unit even more economical.
When starting and under full load, the fuel/air mixture is ignited by a spark plug, as in a conventional spark-ignition engine (homogeneous combustion). The controlled auto ignition to which the DiesOtto automatically reverts within its working cycle occurs under partial load conditions, i.e. at low and medium engine speeds.
The result is the very low nitrogen oxide emissions of homogeneous combustion at reduced reaction temperatures. All further emissions control in the DiesOtto engine is by means of a standard three-way catalytic converter. A highly efficient engine management and control system has also been realised to combine the individual sub-systems into a drive concept.
The current prospects for the future of the internal combustion engine reveal its great potential, and show that the new drive concept is a feasible proposition in the mid-term. Some of the intermediate solutions incorporated, e.g. direct gasoline injection, are already in series production at Mercedes-Benz. Others will be gradually integrated into series-production engines until the overall solution has been realised.
kbonde
Tilmeldt: 02 mar 2005, 16:06
Geografisk sted: Nord
Re: Controlled auto ignition
#2 Indlæg af kbonde »
JakobM skrev: ligesom "variable compression ratio", mener Saab var tidligt på banen her.... :reading:
Var det der de vinklede foringerne i forhold til krumtappen?
HenrikGM
Kontakt:
#3 Indlæg af HenrikGM »
Farten på forbrændingen går ihvertfald op.
Normal flammefront er ~25 krumptapgrader om at nå rundt.
ControlledAutoIgnition er bare 2-4 grader om det samme.
Spændende teknologi, ja, men også voldsomt avanceret.
Da den "tænder" nede omkring 2-4 grader BTDC, så kan man relativt nemt forestille sig at den går i "AutoDestructMode" hvis den tænder for tidligt...Når den brænder så hurtigt, så stiger trykket også tilsvarende hurtigt. Bang sagde det.... :damn:
Saab-Daniel
Tilmeldt: 06 jul 2003, 20:07
Kontakt:
#4 Indlæg af Saab-Daniel »
kbonde skrev: Var det der de vinklede foringerne i forhold til krumtappen?
De skabte variabel kompresion ved at hæve/sænke topstykket. Kompression lå således på 14:1 under dellast osv, og ændrede sig helt ned til, mener jeg, 8.5:1 når der blev kørt hårdt på.
Ærgeligt den motor aldrig kom videre...
Daniel
www.fischer-saab.com
ae86
Tilmeldt: 12 jan 2007, 00:08
#5 Indlæg af ae86 »
Har for et par uger siden lige læst en artikel i Autotechnology hvor Mahle i Tyskland er ved at udvikle et system uden det der advanceret system hvor krumtappen er ophængt i et "forskudt ophæng"
systemet køre som en almindelig sparkignite motor op til et punkt hvor den så skifter over til autoignite
deres system kræver at det er en motor med dirrekte indsprøjtning, mener også der skulle være turbo på den og så skal gasspjæld være elektronisk(e)
ulempen var at den jo kom til at lyde lidt som en diesel, men når man tænker på hvor meget en modernet diesel larmer (eller toms oliebrænder ved lemans) så er det nok et problem man hurtig kommer uden om
så vidt jeg husker fra artiklen så var der noget med ca 5% benzin besparelse ved dirrekte indsprøjtning i forhold til alm indsprøjtning (portinjected) og dirrekte indsprøjtning i forbindelse med autoignition skulle spare en ekstra ~30% :wow: i forhold til "almindelig" dirrekte indsprøjtning eller op i mod 35% i forhold til en almindelig bil i dag, desuden kom man ud over de ulemper man havde med dirrekte indsprøjtning i forbindelse med "lean burn" (de forhøje ??? Nox ??? kan ikke huske hvilken værdier, der er for mange af når forbrændingen er for kold)
Jeg skal prøve at tage artiklen med på arbejde på mandag og scanne den
ind
Jeg havde tænkt på at starte en tråd om emnet men mente at den måske var lige langhåret (nørded) nok
Hvad så Henrik tror du du kan få MS til at styre sådanne et system ??
:wink:
HenrikGM
Kontakt:
#6 Indlæg af HenrikGM »
ae86 skrev:Jeg havde tænkt på at starte en tråd om emnet men mente at den måske var lige langhåret (nørded) nok
:wink:
Langhåret er altid godt.
Hvad angår MS, så har jeg jo næsten af princip den opfattelse at alt er muligt, men jeg tror dæleme der kommer til at mangle nogle nøglefunktioner i MS for at kunne køre sådan en motor uden det siger bang.... :gnaek:
Men dem her kan garanteret klare tricket:
http://www.pectel.co.uk/
Det varer dog nok liige lidt inden at motor, og for den sags skyld styringen er tilgængelige for almindelige mennesker... :wink:
ae86
#7 Indlæg af ae86 »
Så er artiklen scanned, nu skal jeg bare lige finde udaf at få den smidt op et eller andet sted på nettet da den fylder mere end tilladt som attachment på pp
er der nogen der har mulighed for at hoste en ~9mb pdf ??
Jeg skrev før at jeg mente at det var en forudsætning at motoren brugte en turbo, men det er ikke tilfældet, istedet skal den have justerbare knaster på både ind og udstd. siden
CAI : Controlled Auto-Ignition
SI: Spark Ignition (almindelig tænding på en benzin bil)
CI: Compression Ignition (Diesel)
HCCI: Homogeneous Charge Compression Ignition
HCCI er nok det SAAB legede med i deres Variable Geometric Compression motor
ae86
#8 Indlæg af ae86 »
Så kom den på nettet
http://www.yourfilelink.com/get.php?fid=363562
det er en .pdf på ~9mb
så er der :coffee: til de langhåret
JPP
#9 Indlæg af JPP »
Har løst skimmet den. Yderst interessant læsning...
