Dato og tid er 21 okt 2025, 04:16
Indlæg: 21 sep 2012, 23:08
Tilmeldt: 30 jan 2005, 08:54
Helt ny serie MPR turboer med nye 7 bladet billet kompressorhjul og nye 10, 11 eller 12 bladet turbinehjul
Nyt lejesystem, Low Interia, stadig 360 grader lejer, vandkølet (frivilligt/kommer med bolte i vandkanalerne)
Danmarks største program på twin scroll, single scroll, intern wastegate mv. Gennemsnitlig valg mellem 7-10 turbinehuse pr. turbo
Kompressormap på alle modeller
R343
120hp
Compressor Wheel: 34,9/53mm /
Compressor Wheel Type: 6/6 blades
Compressor Wheel Materials: BILLET Forged Aluminum
Compressor Housing Area: 8cm²
Bearing - New MP Racing 360 degree trust bearing - watercooled
Turbine Wheel 33,5/47mm
Turbine Housing Area 4,8cm²
R363, R364
150hp
Compressor Wheel: 35,5/53mm /
Turbine Wheel 35,5/47mm or 42,7/50,4mm
Turbine Housing: 3 option T2 Area from 4,8cm² to 5,4cm²
R444, R4449
360hp
Compressor Wheel: 44/63mm
Turbine Wheel 46/55mm or 49,5/64mm
Turbine Housing: 4 option T2 and T3 Area from 4,1cm² to 13,6cm² Internal/external wastegate, single or twin scroll
R494
500hp
Compressor Wheel: 49/70mm
Compressor Wheel Type: 7/7 blades
Compressor Housing Area: 8cm² - ANTISURGE
Turbine Wheel 49,5/64mm
Turbine Housing: 7 option T3 Area from 6,1cm² to 14,7cm² Internal/external wastegate, single or twin scroll
R544, R545
600hp
Compressor Wheel: 54x77mm
Compressor Housing Area: 13cm² - ANTISURGE
Turbine Wheel 49,5/64mm or 59/70mm
Turbine Housing: 23 options T3 or T4 Area from 6,1cm² to 17cm² Internal/external wastegate, single or twin scroll
R594, R595, R596
650hp
Compressor Wheel: 59/84mm
Compressor Housing Area: 16cm² - ANTISURGE
Turbine Wheel 49,5/64mm or 59/70mm or 64,5/74
Turbine Housing: 35 options T3 and T4 Area from 6,1cm² to 17cm² Internal/external wastegate, single or twin scroll
R6159, R6164, R6168
700hp
Compressor Wheel: 61/88mm
Turbine Wheel 59/70mm or 64,5/74mm or 68/82mm
Turbine Housing: 31 options T3 and T4 Area from 6,7cm² to 25cm² Internal/external wastegate, single or twin scroll
R655, R6564 and R6568
750hp
Compressor Wheel: 65/94mm
Turbine Wheel 59/70mm or 64/74mm or 68/82mm
Turbine Housing: 28 options T3 and T4 Area from 6,7cm² to 25cm² Internal/external wastegate, single or twin scroll
R676, R6771, R6777
800hp
Compressor Wheel: 67/99mm
Compressor Wheel Materials: Cast Aluminum
Compressor Housing Type: A/R 0.66 - 21,3cm2 – ANTISURGE
Turbine Wheel 68/82mm or 71,4/82mm or 77,5/88mm
Turbine Housing: 10 options T4 Area from 19cm² to 25cm² Internal/external wastegate, single or twin scroll
R726, R7271, R7277
840hp
Compressor Wheel: 72/103mm,
Compressor Housing: A/R 0.66 - 21,3cm2 – ANTISURGE
R766, R7671, R7677
1000hp
76,5/103mm
Compressor Housing Area: 22,8cm² - ANTISURGE
Indlæg: 22 sep 2012, 06:59
Findes der en MP turbo der flower omkring 1,5kg/sek med PR omkring 3?
Hvis ja, hvordan er den så konfigureret?(hjuldiametre, etc)
Indlæg: 23 sep 2012, 08:50
Ikke standard, så hedder det (hvis standard) 2 x R76.. det lyder som noget der skal have en plov efter sig, hvad er det til?
Indlæg: 23 sep 2012, 18:04
Tilmeldt: 16 okt 2004, 22:51
Geografisk sted: Vendsyssel
Turboer som f.eks R655 eller R675, hvilken diameter har akslen i dem?
Ole Bundgaard
Indlæg: 23 sep 2012, 18:18
Det har jeg ikke lige ved hånden her. Men jeg kan finde ud af det hvis du ønsker. Jeg vil tro de har ens diameter i R59, R61, R65 serien.
R675 findes ikke, den findes som R676 (68mm exducer), R6771 (71 exducer) eller R7177 (77 exducer). Er vi ude i noget traktor her også?
Indlæg: 23 sep 2012, 21:32
Ja det er vi, det er næsten kun Holset og BorgWarner (Switzer) der bliver brugt til træk, så det er jo altid spændende at kigge efter alternativer. Og med ladetryk omkring de 5 bar kan vi godt lide akseltykkelser omkring de 10-12 mm.
R675 var en tastefejl, mente 676
Ole Bundgaard
Indlæg: 24 sep 2012, 23:04
Ok, jeg undersøger lige hvad akseltykkelserne er
Indlæg: 11 nov 2012, 23:10
Tilmeldt: 25 jun 2006, 19:06
Hvorfor er oversigten og priserne barberet væk fra hjemmesiden?
Virker da ikke særlig snedigt
Indlæg: 11 nov 2012, 23:55
Alle billeder, priser, video mv. af det nye billet "racing" program er på trapperne og snarligt oploadet
Powerpage er blevet europærisk importør og der kommer derfor Europærisk hjemmeside og herunder forhandlernet
Indlæg: 12 nov 2012, 09:10
Ser frem til det.
Indtil da, hvad kan du foreslå til en 1,8 16v 1998 ford motor som bare skal trykkes meget meget moderat, vi snakker fra de oprindelige 105hk til 160 muligvis med senere udvidning mod de 200?
Og hvad koster den?
