Dato og tid er 18 okt 2025, 13:40
Indlæg: 03 jan 2015, 22:06
Tilmeldt: 09 aug 2004, 22:35
Til subaru impreza 92-95 muligvis os senere årgang plug and play styreboks.
Dvs monter tager 10 min og kør
Kom frisk
Kan monteres for dig.
Super fed boks kan man ting tjek det på Google
The Apexi Power FC and the New EL Type Hand Commander 415-A030 proudly stands as A'PEX's answer to the constraints and limitations associated with most piggy-back style fuel controllers. The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path. From multiple point fuel and ignition control to VTEC engagement (Honda applications) and boost settings, the Power FC is capable of accommodating even the most demanding performance enthusiasts.
Installation
Installation is as easy as replacing the factory ECU. (Some minor rewiring is required on select vehicles.) The factory engine harness does not need to be replaced and all critical accessories such as air conditioning continue to function. By using the optional Apexi Power FC Commander, the user can adjust and modify a wide range of settings. By changing various parameters and data, the Apexi Power FC will adapt to any of your performance needs.
The Apexi Power FC also comes preprogrammed with several base maps. (Currently with Japan Domestic Market Vehicle Maps. Minor initial tuning may be required, this makes the initial tuning process much quicker. As with all other fuel controllers, the Apexi Power FC should be tuned on a dynomometer by a trained professional.
Engine Tuning
Setting Mode allows full access to the 20x20 ignition timing and fuel correction maps. The user can adjust any portion of this map in 5x5 sections. Air flow correction values can be entered for vehicles upgrading air flow meters. Injector pulse correction menu is used when upgrading injectors on the engine. The Acceleration Enrichment Correction function improves response under hard and sudden acceleration. The Cranking Fuel Injection menu corrects the amount of fuel when the engine is being cranked, or when the water temperature is cold. A separate Water Temp menu allows fuel correction according to water temperature.
Pris 4000 kr
http://www.bilgalleri.dk/marked/tuning/ ... orstyring-
fiat coupe 2,0 16v turbo
