Dato og tid er 07 nov 2025, 17:20
Indlæg: 31 maj 2010, 17:15
Tilmeldt: 09 aug 2004, 22:35
Aldrig monteret
(fejl køb)
Passer på:
Subaru
Skyline
RX7
Mitsubishi
AE86
AE92
AE101
AE111
AE110
EP71
EP82
EP91
MR2
Nissan
180 SX
EVO
Supra
Og Mange mange flere....
Ny aldrig monteret Let at montere blot 5 ledninger...
Guide her:
http://www.driftworks.com/forum/faq-new ... guide.html
Film af hvad den kan her:
http://www.youtube.com/watch?v=Ej8lUeD4 ... re=related
INGEN BYTTE!!!!
This is Bee*R?s popular two-stage ignition cutting rev-limiter. It is used to prevent damage arising from over-revving your engine. Part of the reason for its popularity is the large flames and loud bangs it produces from the exhaust when active!
The way in which it works differs from the factory rev limiter in that it is an ignition cut, as opposed to a fuel cut. The reason for this is because if an engine (particularly turbocharged) regularly hits a fuel-cut rev limit (such as in high performance driving, or particularly drifting) engine damage can arise due to the lean condition produced when the original ECU shuts off the fuel pump. The BEE*R rev-limiter allows fuel to pass into the engine still, limiting engine speed by disabling the ignition signal. The Bee*R rev limiter is fully adjustable in 500rpm increments, for safety reasons allowing only a lower rev-limit to be configured than standard. If you have spent a lot of money tuning your engine, or are running at high RPM?s for extended periods of time, it could be recommended to run a lower rev-limit to prolong engine life. Both Formula 1 and JGTC cars use ignition cutting rev limiters, so it is a fully race proven concept.
The Bee*R can also be used as a ?two stage rev limiter?, as an aid for launching your car. The Bee*R is configurable for two different rev-limits. A lower rev limit can be activated by a switch, the handbrake switch often being used. This configurable lower limit, can be set to the optimum RPM to launch your particular car from in 500rpm increments. When the handbrake is released, the usual rev limit comes into action, allowing quick launches, and full performance down the strip.
The Bee*R rev-limiter has another final neat feature. The gain control knob allows you to adjust the frequency of the ignition cut. This in turn changes the frequency and sound of the flames and bangs from your exhaust!
Available for use with all rotary, 4 and 6 cylinder engines. (No V8 application)
NEW IN- Type H Rev-limiter suitable for use with Honda?s!
Please select the appropriate type from the list below.
Note: We would recommend the fitment of a Cat. Replacement pipe when fitting this item if not already fitted to the vehicle otherwise the catalyser may become damaged over time when the device is active. A cat replacement pipe will also allow flames to become more visible from the exhaust when the device is active. See our exhausts section for these. Some addional wiring may be required if using in conjunction with an aftermarket ECU.
(TYPE B)
Fotos: http://www.bilgalleri.dk/html/mar_vis.asp?MarID=1018399
Pris: 2000 kr
Kan tages med til DHB
fiat coupe 2,0 16v turbo
http://www.bilgalleri.dk/html/gal_visbil.asp?ID=95132
