Amerikansk lovgivning
: 19 dec 2008, 21:06
Grunden til at bla. den Amerikanske E-type ikke har glas foran lygterne som den "rigtige" 3.6L model har
Det er da heldigvis blevet ændret idag
_________________________________________________
Rectangular headlamps were prohibited in the United States where round lamps were required until 1975. By 1979, the majority of new cars now had the rectangular headlamps. Again, the U.S. permitted only two standardized sizes of rectangular sealed-beam lamp: A system of two 200 mm x 142 mm high/low beam units corresponding to the existing 7" round format, or a system of four 165 mm x 100 mm units (two high/low and two high-beam) corresponding to the existing 5¾ inch (146 mm) round format.
In 1968 the U.S. DOT outlawed any decorative or protective element in front of the headlamps whenever the headlamps are switched on. Glass-covered headlamps, used on e.g. the Jaguar E-Type, the pre-1968 VW Beetle, the Porsche 356, the Citroën DS and Ferrari Daytona) therefore had to be equipped with uncovered headlamps for the US market, further altering the look of European models sold in the United States. This change meant that vehicles designed for solid aerodynamic performance could not achieve it for the US market. In 1984, the DOT changed this rule, allowing replaceable-bulb headlamps of nonstandard shapes. However, this change did not mean that an automaker could equip a vehicle with the same type of headlamps in the US as in the rest of the world. United States headlamp standards are governed by Federal Motor Vehicle Safety Standard 108, which is incompatible with the UNECE standards used in most of the rest of the world. Canada has its own headlamp standards similar to the US standard, but allows UNECE-compliant headlamps.
