fra lav ohm til høj ohm
: 14 sep 2006, 23:29
af Mark
Hvad skal man tjekke i Megatune ved sådan et dyse skift ?
software version 24s13c
: 19 sep 2006, 10:49
af Mark
upp..... hvordan skal de PWM settings stå ? ved højohms dyser
: 19 sep 2006, 11:26
af Saab-Daniel
Her er snippet lidt fra vejledningen på www.megasquirt.info
On the Settings/Constants page:
If you are running high-impedance injectors (greater than 10 Ohms), then set the:
PWM Time Threshold to 25.4 msec, and the
PWM Current Limit (%) to 100%.
If you have low impedance injectors (less than 4 Ohms), set the:
PWM Time Threshold to 1.0 msec, and
PWM Current Limit to 75%(30% if you have installed the 'Flyback Board' daughter card).
You will tune these after getting the engine running. See “Setting the PWM Criteria” in this section. Failure to perform these steps can result in damage to your injectors. If you have high-impedance injectors, set these values to 25.4 ms and 100%, and you do not need to tune them further.
Søg mere info her:
http://www.megamanual.com/v22manual/mtune.htm
Daniel.
