eltubo
#11 Indlæg af lqs »
synes det ville være mere retfærdigt at sammenligne med N2O! ikke at elkompressoren kommer til at stå stærkere af den grund.....tvært imod! MVH. søren
#12 Indlæg af Gæst »
tak
2006burger
Tilmeldt: 08 maj 2004, 21:04
#13 Indlæg af 2006burger »
http://www.esuperchargers.com/ det her er også sådan en "el turbo" lige til at sætte på :D
Nolan
Geografisk sted: Østjylland
#14 Indlæg af Nolan »
Fra siden:
The Jet Stream™ Electric Supercharger is capable of boost levels up to 2psi!! Finally for or a fraction of the cost of a normal Supercharger you can receive similar increases in horsepower. With our instructions you will be able to build and install your own Jet Stream™ Electric Supercharger within a matter of hours. The total cost of all parts needed is less than $80.00. Our kit takes absolutely no mechanical skill to build and install and will immediately be capable of delivering a 5-20% boost in horsepower throughout the entire RPM band GUARANTEED or your money back!
These units are extremely easy to install and operate, and offer performance gains unmatchable for the price!! Up to 30 Horsepower on some vehicles! Along with this horsepower increase you will also benefit from a savings in your gas mileage up to 10% or more! The Electric Supercharger is available for all vehicle makes and models and parts are readily available from a variety of sources worldwide! Stop wasting your money on expensive mods that only add a fraction of power and download your Electric Supercharger Instructions Today!
Imponerende: 2psi der giver en forøgelse på 5-20%.....
Der kan da ikke være meget tvivl om at man SKAL have sådan én....
:shock:
/Nolan
#15 Indlæg af Gæst »
det kunne være sjovt nok om det lort det virker bare for at prøve :lol:
MC
Tilmeldt: 12 jul 2003, 22:59
#16 Indlæg af MC »
Anonymous skrev:det kunne være sjovt nok om det lort det virker bare for at prøve :lol:
Jamen så syntes jeg da du skulle tage at købe en. tag bilen på rullefelt, monter elturboen og en gang mere på rule felt. Så hvis det ikke giver min 5% så kan du sende den retur. dvs. 5 heste for hver 100 bilen har.
2006burger
#17 Indlæg af 2006burger »
jeg har altså også virklige gået og tænkt på det bare for sjov :lol:
Nolan
#18 Indlæg af Nolan »
Der er altså flere her, der har mange penge de vil bruge på noget der ikke virker - bare for sjov !!!!!
:shock:
Spar nu de penge... Det dur IKKE !
Prøv nu bare at sætte en hånd foran jeres luftfilter og mærk hvad der sker, når i giver den noget gas....
En motor suger fandme noget luft - mange biler æder hvad der svarer til rumfanget af en LT varevogn hvert minut !!
En kabinetblæser fra en udslidt PC kan ikke levere noget tryk i indsugningen, basta !! Sådan er det bare !
Køb et lattergas-sæt istedet. Det er billigt i forhold til de muligheder det giver.
/Nolan
