NYE MASTER POWER Racing Turbo'er - Kompressor Maps http://powerforum.dk/viewtopic.php?f=4&t=25803 |
Side 1 af 2 |
Forfatter: | JPP [ 21 sep 2012, 23:08 ] |
Titel: | NYE MASTER POWER Racing Turbo'er - Kompressor Maps |
Helt ny serie MPR turboer med nye 7 bladet billet kompressorhjul og nye 10, 11 eller 12 bladet turbinehjul Nyt lejesystem, Low Interia, stadig 360 grader lejer, vandkølet (frivilligt/kommer med bolte i vandkanalerne) Danmarks største program på twin scroll, single scroll, intern wastegate mv. Gennemsnitlig valg mellem 7-10 turbinehuse pr. turbo Kompressormap på alle modeller R343 120hp Compressor Wheel: 34,9/53mm / Compressor Wheel Type: 6/6 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 8cm² Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 33,5/47mm Turbine Housing Area 4,8cm² R363, R364 150hp Compressor Wheel: 35,5/53mm / Compressor Wheel Type: 6/6 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 8cm² Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 35,5/47mm or 42,7/50,4mm Turbine Housing: 3 option T2 Area from 4,8cm² to 5,4cm² R444, R4449 360hp Compressor Wheel: 44/63mm Compressor Wheel Type: 6/6 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 8cm² Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 46/55mm or 49,5/64mm Turbine Housing: 4 option T2 and T3 Area from 4,1cm² to 13,6cm² Internal/external wastegate, single or twin scroll ![]() R494 500hp Compressor Wheel: 49/70mm Compressor Wheel Type: 7/7 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 8cm² - ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 49,5/64mm Turbine Housing: 7 option T3 Area from 6,1cm² to 14,7cm² Internal/external wastegate, single or twin scroll ![]() R544, R545 600hp Compressor Wheel: 54x77mm Compressor Wheel Type: 7/7 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 13cm² - ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 49,5/64mm or 59/70mm Turbine Housing: 23 options T3 or T4 Area from 6,1cm² to 17cm² Internal/external wastegate, single or twin scroll ![]() R594, R595, R596 650hp Compressor Wheel: 59/84mm Compressor Wheel Type: 7/7 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 16cm² - ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 49,5/64mm or 59/70mm or 64,5/74 Turbine Housing: 35 options T3 and T4 Area from 6,1cm² to 17cm² Internal/external wastegate, single or twin scroll ![]() R6159, R6164, R6168 700hp Compressor Wheel: 61/88mm Compressor Wheel Type: 7/7 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 16cm² - ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 59/70mm or 64,5/74mm or 68/82mm Turbine Housing: 31 options T3 and T4 Area from 6,7cm² to 25cm² Internal/external wastegate, single or twin scroll ![]() R655, R6564 and R6568 750hp Compressor Wheel: 65/94mm Compressor Wheel Type: 7/7 blades Compressor Wheel Materials: BILLET Forged Aluminum Compressor Housing Area: 16cm² - ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 59/70mm or 64/74mm or 68/82mm Turbine Housing: 28 options T3 and T4 Area from 6,7cm² to 25cm² Internal/external wastegate, single or twin scroll R676, R6771, R6777 800hp Compressor Wheel: 67/99mm Compressor Wheel Type: 7/7 blades Compressor Wheel Materials: Cast Aluminum Compressor Housing Type: A/R 0.66 - 21,3cm2 – ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 68/82mm or 71,4/82mm or 77,5/88mm Turbine Housing: 10 options T4 Area from 19cm² to 25cm² Internal/external wastegate, single or twin scroll ![]() R726, R7271, R7277 840hp Compressor Wheel: 72/103mm, Compressor Wheel Type: 6/6 blades Compressor Wheel Materials: Cast Aluminum Compressor Housing: A/R 0.66 - 21,3cm2 – ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 68/82mm or 71,4/82mm or 77,5/88mm Turbine Housing: 10 options T4 Area from 19cm² to 25cm² Internal/external wastegate, single or twin scroll R766, R7671, R7677 1000hp 76,5/103mm Compressor Wheel Type: 6/6 blades Compressor Wheel Materials: Cast Aluminum Compressor Housing Area: 22,8cm² - ANTISURGE Bearing - New MP Racing 360 degree trust bearing - watercooled Turbine Wheel 68/82mm or 71,4/82mm or 77,5/88mm Turbine Housing: 10 options T4 Area from 19cm² to 25cm² Internal/external wastegate, single or twin scroll |
Forfatter: | HenrikGM [ 22 sep 2012, 06:59 ] |
Titel: | |
Findes der en MP turbo der flower omkring 1,5kg/sek med PR omkring 3? Hvis ja, hvordan er den så konfigureret?(hjuldiametre, etc) |
Forfatter: | JPP [ 23 sep 2012, 08:50 ] |
Titel: | |
HenrikGM skrev: Findes der en MP turbo der flower omkring 1,5kg/sek med PR omkring 3?
Hvis ja, hvordan er den så konfigureret?(hjuldiametre, etc) Ikke standard, så hedder det (hvis standard) 2 x R76.. det lyder som noget der skal have en plov efter sig, hvad er det til? |
Forfatter: | wukshady [ 23 sep 2012, 18:04 ] |
Titel: | |
Turboer som f.eks R655 eller R675, hvilken diameter har akslen i dem? |
Forfatter: | JPP [ 23 sep 2012, 18:18 ] |
Titel: | |
wukshady skrev: Turboer som f.eks R655 eller R675, hvilken diameter har akslen i dem?
Det har jeg ikke lige ved hånden her. Men jeg kan finde ud af det hvis du ønsker. Jeg vil tro de har ens diameter i R59, R61, R65 serien. R675 findes ikke, den findes som R676 (68mm exducer), R6771 (71 exducer) eller R7177 (77 exducer). Er vi ude i noget traktor her også? |
Forfatter: | wukshady [ 23 sep 2012, 21:32 ] |
Titel: | |
Ja det er vi, det er næsten kun Holset og BorgWarner (Switzer) der bliver brugt til træk, så det er jo altid spændende at kigge efter alternativer. Og med ladetryk omkring de 5 bar kan vi godt lide akseltykkelser omkring de 10-12 mm. R675 var en tastefejl, mente 676 |
Forfatter: | JPP [ 24 sep 2012, 23:04 ] |
Titel: | |
wukshady skrev: Ja det er vi, det er næsten kun Holset og BorgWarner (Switzer) der bliver brugt til træk, så det er jo altid spændende at kigge efter alternativer. Og med ladetryk omkring de 5 bar kan vi godt lide akseltykkelser omkring de 10-12 mm.
R675 var en tastefejl, mente 676 Ok, jeg undersøger lige hvad akseltykkelserne er |
Forfatter: | Runesm [ 11 nov 2012, 23:10 ] |
Titel: | |
Hvorfor er oversigten og priserne barberet væk fra hjemmesiden? Virker da ikke særlig snedigt |
Forfatter: | JPP [ 11 nov 2012, 23:55 ] |
Titel: | |
Alle billeder, priser, video mv. af det nye billet "racing" program er på trapperne og snarligt oploadet Powerpage er blevet europærisk importør og der kommer derfor Europærisk hjemmeside og herunder forhandlernet |
Forfatter: | Runesm [ 12 nov 2012, 09:10 ] |
Titel: | |
JakobM skrev: Alle billeder, priser, video mv. af det nye billet "racing" program er på trapperne og snarligt oploadet
Powerpage er blevet europærisk importør og der kommer derfor Europærisk hjemmeside og herunder forhandlernet Ser frem til det. Indtil da, hvad kan du foreslå til en 1,8 16v 1998 ford motor som bare skal trykkes meget meget moderat, vi snakker fra de oprindelige 105hk til 160 muligvis med senere udvidning mod de 200? Og hvad koster den? |
