Dato og tid er 02 nov 2025, 09:37
Indlæg: 23 apr 2009, 20:23
Tilmeldt: 09 aug 2004, 22:35
The Omex Rev Limiter Clubman with Launch Control features an extremely smooth rev-limiting action and a selectable hard or soft cut.
It also has an auxilliary rev limit which is operated with the supplied waterproof switch that can be mounted on the stearing wheel or the gear knob.
Set separately to the main rev limit, the auxilliary limit is used at the startline to prevent wheel spin or the engine `bogging down` enabling very consistant results.
The unit is suitable for most 2, 4, 6, or 8 cylinder single coil engines that use points, electronic, or ECU ignition. The twin coil version is designed for use on 4 cylinder twin coil (DIS) engines.
OMRLCLC Rev Limiter Clubman with Launch Control
OMRLCLCT Rev Clubman with Limiter Launch Control Twin Coil
nypris 1400 kr
Sælges for blot 700 kr
(kan sikkert også bruges til biler med enkel tændspole...)
Er ikke brugt ret meget....
fiat coupe 2,0 16v turbo
http://www.bilgalleri.dk/html/gal_visbil.asp?ID=95132
